01-02-2009 12:12 PM - edited 03-18-2019 10:13 PM
This event points to network problem?
Event Type: Information
Event Source: CiscoUnity_TSP
Event Category: None
Event ID: 145
Date: 1/2/2009
Time: 2:25:43 PM
User: N/A
Computer: xxxxxxxxx
Description:
Cisco Unity-SCCP TSP device 20 (Cisco Unity port 16): Connected to CUCM server 10.80.240.26:2000. This is not the primary CUCM server in this cluster, so Cisco Unity will periodically attempt to failback to the primary server, if configured to do so.
Failover Technical Details: FailTCPConnect
The Cisco Unity-SCCP TSP version is 8.3(1.0)
01-02-2009 01:11 PM
If you have many of them, then possibly. What this is saying is that you have another CUCM in your UTIM listed as the primary CUCM you want your ports to connect with. Right now, port 16 is connected but it is connected to a CUCM that is not your primary designated CUCM. If your CUCM cluster is configured right, then this should affect any functionality as the ports seem to be registered with another CUCM that should be able to communicate with the Unity. Regardless, something is up with connectivity to your primary CUCM and you should investigate it.
Tray
01-02-2009 01:29 PM
this is happening on multiple ports,
what would happen to a active call in such a scneraio, would it disconnect or failover?
Avinash
