Jan 2nd, 2009
I am studying for the CCNP and I am setting up a simple BGP connection between two routers but can't get it to work.
Here are the configs.
Router A
int lo0
ip add
int fa0/0
ip add
router bgp 1
neighbor remote-as 2
Router B
int lo0
ip add
int fa0/0
ip add
router bgp 2
neighbor remote-as 1
Any reason why this isn't connecting? Physical layer is good as I can ping connected interfaces from both sides.
Giuseppe Larosa Sat, 01/03/2009 - 05:10
Hello Richard,
a useful command is
sh ip bgp summary
as you have just discovered is possible to build a BGP session without advertising nothing.
in this case you see 0 as the number of prefixes received.
If you use sh ip route bgp you don't see nothing but the BGP session is up.
Think of BGP session as a communication channel between two devices
Hope to help
