Monitoring error in Switches (3750, 6500, 3560)
Answered Question
Jan 2nd, 2009
Hi guys,
Is there any way on how to manually monitor error in switches (like loops, interface down, CPU usage, bandwidth usage)? using only commands in switch/router. Thanks.
Cheers!
Correct Answer by MUHAMMAD SHAHEEN about 8 years 1 month ago
the best command to use is #Show Process [memory] or [CPU]. These 2 options give you a lot of details.
You can also use #Show process CPU history. This will give a graph over last 60 minutes, few hours etc.
Hope This Helps...
Shaheen
Overall Rating: 5 (1 ratings)
Correct Answer
MUHAMMAD SHAHEEN Sun, 01/04/2009 - 09:52
Hope This Helps...
Shaheen
gagamboy15 Mon, 01/05/2009 - 00:20
Hello Guys Thanks. Yes, there is no one command but show process will help a lot. :-)
Thanks again.
Cheers!
