JORGE RODRIGUEZ Sat, 01/03/2009 - 11:12
  • Green, 3000 points or more
Im not clear of your question, do you need to get back in to PIX , you do not know the passwords? or is it simply to change/reset the current passwords?
if to change passwords, bellow is the process to change password for telnet password and enable passwords, there is no default passwords in already configured firewall. PLS indicate if this is not the case.
seting password for telnet access
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/mr.html#wp1026924
pix(config)#passwd
Seting password for enable mode
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/df.html#wp1028841
pix(config)#enable password
after reseting these passwords before you logout and prior saving config telnet back into PIX from another system to test new passwords if all ok then you can save changes pix#write mem
These syntax commands applies to all fws regardless of code .
Also reseting passwords does not interact with PIX licensing information, nor reseting to factory defaults, but as good practice is always good to save the output of show version which will have PIX licensing KEYs.
PLS rate any helpful posts
Amin Shaikh Sat, 01/03/2009 - 12:16
Thanks.
Sorry the wordings where not correct.
I need to know how to recover lost password for PIX 525.
