No startup
Jan 3rd, 2009
Hi ALL:
Happy New Year
I am getting this error when trying to copy the run to start up could any one explain the reason.
Router#cop
Router#copy run
Router#copy running-config st
Router#copy running-config startup-config
Destination filename [startup-config]?
startup-config file open failed (No such file or directory)
Router#
Router#sh star
Router#sh startup-config
Using 1821 out of 196600 bytes
%Error opening nvram:/startup-config (No such file or directory)
Router#
Router#
Router#copy startup-config running-config
%% Non-volatile configuration memory invalid or not present
Router#
Router#sh flash
Router#sh flash:
-#- --length-- -----date/time------ path
1 1821 Dec 28 2007 00:48:26 +00:00 sdmconfig-18xx.cfg
2 861696 Dec 28 2007 00:48:50 +00:00 es.tar
3 1164288 Dec 28 2007 00:49:16 +00:00 common.tar
4 1038 Dec 28 2007 00:49:40 +00:00 home.shtml
5 113152 Dec 28 2007 00:50:04 +00:00 home.tar
6 20570916 Feb 23 2008 07:30:52 +00:00 c1841-spservicesk9-mz.124-16b.bin
9203712 bytes available (22728704 bytes used)
Router#
Router#
Router#sh ver
Cisco IOS Software, 1841 Software (C1841-SPSERVICESK9-M), Version 12.4(16b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 19-Dec-07 23:28 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 47 minutes
System image file is "flash:c1841-spservicesk9-mz.124-16b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FHK115225UY
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Chao
Vishwa
Richard Burts Sat, 01/03/2009 - 15:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Vishwa
This is a very unusual symptom. Would you post the output of show file system from this 1841.
Rick
stalin_cisco Sat, 01/03/2009 - 23:04
Vishwa,
This case is happend due to buffer issue in NVRAM.We have to clear NVRAM,so erase the NVRAM and try ..it will work..
Command - Router#erase nvram:
after clearing the NVRAM don't restart the router without copy the config to start-up.
STALIN P
vishwancc Sun, 01/04/2009 - 20:51
Thanks Guys ,
For the reply issue is resolved.
I dont know why it was happenning i did the same step after reload and it worked .
Crazy Ciso.
Chao
Vishwa
Richard Burts Mon, 01/05/2009 - 05:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vishwa
Thank you for posting back and telling us that the issue was resolved when you reloaded the router. It makes the forum more useful when people can read about a problem and can read what was done that resolved the problem.
Rick
