switch port in access mode, dscp-cos mapping
Jan 3rd, 2009
Hi everybody!
I have a question.
Scenario:
sw1's f0/1 configured with following:
mls qos trust dscp
When f0/1 is in access mode:
When a switch receives the frame , Would switch drive the cos value from DScp-cos map even though the port is in access mode and place the frame in respective queue at ingress port?
thanks a lot!
Jon Marshall Sat, 01/03/2009 - 12:20
Sarah
The Cos value is derived from the DSCP-Cos map for egress traffic not ingress traffic. This map is needed because the switch always uses an internal DSCP value for all packets.
Using a 3560 switch as an example, you decide which marking, DSCP or CoS, will be used to place the packets into the ingress queues.
So the switch derives the CoS value or the DSCP value from the incoming packet and then maps this to the relevant queue.
Jon
