Adding new switch to stack
Jan 3rd, 2009
Any advice appreciated. I have a new un-configured - 'out of the box' 3750 switch. I want to add this switch to an existing switch stack. Is it as simple as just adding it to the bottom of the stack with the stackwise cables? will it then receive the correct config from the master? Is there anything that I should configure on the new switch first? There is no chance of the new switch becoming the master and interferring with the existing config of the stack?
Thanks in advance!
Giuseppe Larosa Sat, 01/03/2009 - 13:31
Hello Mike,
here it is the doc
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
To be sure that the new switch will not become the master you should increase the priority of the current master.
see the section
Tips to Add a Switch as a Slave to the Stack
you need to have the right image (the same) on the new switch and you can set to 1 its switch priority.
The other option is adding a provisioned switch to the stack (that perhaps you didn't like)
Hope to help
Giuseppe
