ASA 5505 / Proto41 or 6in4
Jan 3rd, 2009
does anyone know if the ASA5505 supports 6in4/proto41? I know it doesn't support terminating anything other then an IPSec connection, so it seems like my only option would be to go with a provider called sixxs which does have an option that supports ipv6 tunnels for computers doing NAT, however proto41 support is required.
godinerik Sun, 01/04/2009 - 00:31
*bump*
If this isn't supported yet, anyone knows where I can make a feature request?? Being able to terminate an IPv6 tunnel on the 5505 would be even better, however I'm not getting my hopes up for that one.
Erik
godinerik Sun, 01/04/2009 - 09:13
Hi Jorge,
Unfortunately although IPv6 support is there, this would require native IPv6 (i.e.: outside interface) and my connection at the DC isn't native IPv6. The two other possibilities are:
- If the ASA could terminate IPv6 tunnels (like I said, not holding my breath for this one, this feature is found on their routers)
- If Proto41 (ip6in4) would be supported
Thanks for your suggestion, I'll open a TAC case.
godinerik Sun, 01/04/2009 - 09:15
On a different note, I noticed Apple's airport extreme home routers support this. Kind of pricey ($175) but I guess you gotta pay to play. If ?I wouldn't be so cheap (and I know I shouldn't, eventually I'll get there) I'd surf eBay for a second-hand cisco router, but of course this would mean using another U
