show mls qos int fo/1 commmand
Answered Question
Jan 4th, 2009
  • Bronze, 100 points or more
hi every body!
i have few questions about the command :
switch# show mls qos int fastethernet 0/1
trust state: trust cos
trust mode: trust cos
trust enabled flag: ena
trust device: none
1)Trust state: trust cos is it because the of the command mls qos trust cos?
2) trust mode: trust cos is it because of the command mls qos trust cos ?
3)trust enabled: ena which command cause this?
4)trust device: none
what does it shows? when could trust device could show" cisc0-phone?
thanks a lot!
Correct Answer by Jon Marshall about 8 years 3 months ago
Sarah
1) Yes
2) Yes. When you use the "mls qos trust cos" command you are basically unconditionally trusting whatever CoS values are received in packets on that port.
When you use the "mls qos trust device cisco-phone" you are setting up a conditional trust ie. the condition being that there must be a Cisco IP Phone connected into that port for the switch to trust the CoS markings.
This is to stop someone unplugging the phone, connecting their PC directly to the port and then setting CoS/DSCP markings in the packets to get preferential treatment.
Jon
Sarah
"Trust state was trust cos before, but after you configured the switch to trust cisco phone, i find trust state : not trusted
what happened here?"
You are going to make a very good network person :-)
From the 3550 configuration doc -
The trusted boundary feature prevents security problems if users disconnect their PCs from networked Cisco IP phones and connect them to the switch port to take advantage of trusted CoS or DSCP settings. You must globally enable the Cisco Discovery Protocol (CDP) on the switch and on the port connected to the IP phone. If the telephone is not detected, trusted boundary disables the trusted setting on the switch or routed port (sets the trust state to not trusted) and prevents misuse of a high-priority queue.
Unfortunately i don't have a Cisco phone handy so it will mark it as untrusted but if we plugged a Cisco phone in then CDP should detect it and change the state to trusted.
Jon
Sarah
I keep promising to fire up my switches so i just did. On a 3550 there is no "trust flag" field but here is output
mls qos enabled globally but no trust enabled on interface
SW1#sh run int fa0/5
Building configuration...
Current configuration : 107 bytes
interface FastEthernet0/5
switchport access vlan 2
switchport mode access
spanning-tree portfast
end
SW1#sh mls qos int fa0/5
FastEthernet0/5
trust state: not trusted
trust mode: not trusted
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
Configure fa0/5 to trust cos
SW1(config)#int fa0/5
SW1(config-if)#mls qos trust cos
FastEthernet0/5
COS override: dis
default COS: 0
Trust device: none
Then tell interface to trust a cisco phone
SW1(config-if)#mls qos trust device cisco-phone
FastEthernet0/5
COS override: dis
default COS: 0
Trust device: cisco-phone
Jon
Overall Rating: 5 (3 ratings)
Correct Answer
Jon Marshall Sun, 01/04/2009 - 12:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sarah
end
FastEthernet0/5
COS override: dis
default COS: 0
Trust device: none
FastEthernet0/5
COS override: dis
default COS: 0
Trust device: none
FastEthernet0/5
COS override: dis
default COS: 0
Jon
sarahr202 Sun, 01/04/2009 - 13:31
Thanks a lot Jon! You just saved me headache. My book, of which I am not a great fan of, shows the out put of the command but did not go into any details.
Towards the end of your post,let me quote
FastEthernet0/5
COS override: dis
default COS: 0
what happened here?
thanks a lot!
Correct Answer
Jon Marshall Sun, 01/04/2009 - 15:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sarah
Jon
sarahr202 Sun, 01/04/2009 - 17:32
I am going to focus on two things.
trust device: cisco-phone
1) trust device: cisco-phone indicates the port is configured with " mls qos trust device cisco-phone" right or wrong?
2) trust state: not trusted indicates that device plugged in is not the cisco-phone, thus trust state: not trusted right or wrong?
thanks a lot Jon and have a good night!
Correct Answer
Jon Marshall Mon, 01/05/2009 - 02:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sarah
1) Yes
Jon
