01-04-2009 09:41 PM - edited 03-04-2019 03:19 AM
I can't get cisco 857 sync with telstra bigpond adsl service. It won't get into the showtime status. Attached is the screen capture for debuging atm event. The attenuation is so high (61db) as I can tell. But it uses 2wire modem connected to the adsl service fine. If the attenuation cant be reduced because of the distance, is there a way to use cisco router?
01-05-2009 12:50 AM
Hello Lydia,
or your router is facing an interoperability issue with the remote end OR the ADSL card in the router is not working properly.
If you have a web access to the 2wire modem you can try to read the attenuation for this device if is very different there are chances your router DSL interface is defective.
000692: *Dec 15 15:52:26.411 Sydney: DSL(ATM0): Received response: 0x16
000693: *Dec 15 15:52:26.411 Sydney: DSL(ATM0): Far End Chip Country Code 0xB5
000694: *Dec 15 15:52:26.411 Sydney: DSL: Far End Chip Vendor ID BDCM
000695: *Dec 15 15:52:26.411 Sydney: DSL: Far End Chip Vendor ID Specific 0x544D
000696: *Dec 15 15:52:26.411 Sydney: DSL: Far End ITU Vendor STD Number 0x0002
000697: *Dec 15 15:52:26.411 Sydney: DSL(ATM0): Sent command 0x32
000698: *Dec 15 15:52:26.415 Sydney: DSL(ATM0): Received response: 0x14
000699: *Dec 15 15:52:26.415 Sydney: DSL(ATM0): Near End Chip Country Code 0x0F
000700: *Dec 15 15:52:26.415 Sydney: DSL: Near End Chip Vendor ID STMI
000701: *Dec 15 15:52:26.415 Sydney: DSL: Near End Chip Vendor ID Specific 0x0000
000702: *Dec 15 15:52:26.419 Sydney: DSL: Near End ITU Vendor STD Number 0x0003
000703: *Dec 15 15:52:26.419 Sydney: DSL(ATM0): Sent extended command 0x5
000704: *Dec 15 15:52:26.423 Sydney: DSL(ATM0): Near End Modem Country Code 0xB5
000705: *Dec 15 15:52:26.423 Sydney: DSL: Near End Modem Vendor ID CSCO
I see you have 12.4(15)T7 version of IOS
000707: *Dec 15 15:52:26.423 Sydney: DSL: Near End Modem Version 12.4(15)T7
You could also try to update IOS image to a newer version in the hope a new firmaware version for the DSL card is installed.
go to 12.4(20)T or later.
Hope to help
Giuseppe
