Renew my CCNA
Jan 4th, 2009
My CCNA just expired last year (2008). I would like to re-certify. So, I have 2 questions:
1. Is the CCNA now called 640-802? 3 years ago it was 640-801
2. Can I just go with CCNA Security, and this will automatically update my CCNA?
rob.huffman Mon, 01/05/2009 - 06:10
Hi Roman,
Sadly, you will need to start over now that your CCNA has expired. The CCNA has two flavours, either the single exam 640-802 or the 2-part exam 640-822 ICND1 with 640-816 ICND2. The pre-requisite for the CCNA Security is a valid CCNA :)
CCNA Exams
Required Exam(s)
640-802 CCNA
Or the 2 - Part Version
640-822 ICND1
640-816 ICND2
http://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
CCNA Security Prerequisites
**Valid CCNA
http://www.cisco.com/web/learning/le3/le2/le0/le1/learning_certification_type_home.html
Hope this helps!
Rob
rob.huffman Mon, 01/05/2009 - 15:33
Hi Roman,
You are most welcome! Best of luck with your upcoming studies.
Cheers!
Rob
