Telepresence/MeetingPlace/MCU
billybjo1
Level 3
Level 3
I need to design a VC solution and I'm struggling to find answers to a few questions:
1) Can Telepresence integrate with MP Express and be scheduled via that?
2) Can Telepresence be used with a Cisco MCU?
3) Can VTA and other 3rd party units (i.e. Tandberg) be part of the same VC that Telepresence takes part in?
Basically I want to establish if its even worth considering Telepresence in a MP integration, or should we go for 3rd party systems?
Thanks.
Hi Billi,
Will try to answer whtever I am aware of -
ANS - No Clue :(
ANS - Yes, TP can be used with Cisco MCU but for the integration purpose. Meaning you have other video devices (other than telepresence), and want to have a session between TP and these endpoints then you place a MCU in between. all other devices will be registered to MCU and MCU will talk to Telepresence multipoint switch.
If you question is can MCU act as a replacement of Multipoint Switch for TP endpoints the answer is NO.
ANS - Yes, by using MCU.
heres a good link on the interoperability -
http://www.cisco.com/en/US/docs/telepresence/multipoint_switch/1_1/admin/guide/dh_interop_2.html
-> Sushil
