Replacing 26xx with 2851 voice gtw
Answered Question
Jan 5th, 2009
Hi!
we have used 2651XM for years as a voice gtw with E1 link.
Now, I have replaced it with 2851 router and I`am using the same one E1 link!
now, there is no problems with voice call (everything works fine), but under E1 controller status I see lot of errors!
E1 0/0/0 is up.
Applique type is Channelized E1 - unbalanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20050620, FPGA: 16, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (161 seconds elapsed):
1 Line Code Violations, 1 Path Code Violations
24 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins
25 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
110 Line Code Violations, 114 Path Code Violations,
12884 Slip Secs, 0 Fr Loss Secs, 109 Line Err Secs, 0 Degraded Mins,
12979 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
IOS: c2800nm-spservicesk9-mz.124-3i.bin
How to solve this errors?
thx
Correct Answer by Nicholas Matthews about 8 years 2 weeks ago
try network-clock-select 1 e1 0/0/0
Should clear that up for you.
hth,
nick
Overall Rating: 5 (1 ratings)
iptuser55 Mon, 01/05/2009 - 03:51
Have you checked the Network-clock-participate and network-clock on the router also where are you clocking from ?
darijohorvat Mon, 01/05/2009 - 05:36
you mean on router which provides clock? can`t check it, it is provider equipment.
But, nothing was changed on that line (line physicaly remain the same), only my router was replaced!
in configuration I see this command:
network-clock-participate wic 0
Should this be turned off?
