Cisco Works - sharing layout in CM Topology Services
Jan 5th, 2009
In Cisco Works, Campus Manager, Visuliazation, Topology Services when making a Display View under for instance VTP Views you get the opportunity of saving the current view layout.
I have put some time into the different layouts representing our network, and would like colleagues to have the opportunity of using these layouts. But layouts are saves on a per user basis.
Does somebody know how to point any Cisco Works users default layout to a saved (shared) layout, or any other way to acheive this? I cannot find any directions in the manual.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 01/05/2009 - 09:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can manually copy the XML files and preferences from one user's settings to another. This will effectively copy the layouts. Simply copy all off the files under NMSROOT/campus/etc/users/USERNAME to the new user's USERNAME directory. For example, to copy admin's settings to a user, jclarke, copy all of the files under NMSROOT/campus/etc/users/admin to NMSROOT/campus/etc/users/jclarke.
peter.krohn Fri, 01/09/2009 - 02:28
This was exactly what I needed - I'll just automatically every week/day copy the XML to all users. THX :)
