Unable to ssh ASA management interface
Jan 5th, 2009
I have defined the ca key pair and allowed the source network on 'ssh' command with corresponding interface. The aaa authentication for ssh is LOCAL.
I can successfully ssh into the inside interface but not management. Is anything else required to ssh into management interface.
Collin Clark Mon, 01/05/2009 - 06:15
  • Purple, 4500 points or more
Are you permitting ssh on the management interface?
ssh 10.1.2.75 255.255.255.255 management
cisco_lite Mon, 01/05/2009 - 06:52
Yes. I have permitted /24 network and not specific host.
Collin Clark Mon, 01/05/2009 - 06:54
Have you tried to debug ssh while trying to connect?
cisco_lite Mon, 01/05/2009 - 09:13
debug ssh is blank and does not give any information on ASA.
Collin Clark Mon, 01/05/2009 - 09:22
OK, it sounds like your not even hitting the management interface. You can try debugging ICMP trace and try and ping the management interface. If you get no output from the debug, verify connectivity to the management interface.
