ios uploading using xmodem in 3750 switch
Giuseppe Larosa Mon, 01/05/2009 - 04:43
  • Hall of Fame,
    Founding Member
Hello Shiva,
you can use the procedure
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_14_ea1/configuration/guide/swtrbl.html#wp1099467
note: setting the speed to 11500 bps can save hours of download time I did it you need the change the parameters on the device and then on the PC terminal emulator before starting the download.
but if you didn't switch off the switch you can use TFTP to write the image on your flash becuase you still have an IOS running
Hope to help
Giuseppe
