01-05-2009 04:36 AM - edited 03-04-2019 03:19 AM
Hi All;
i have some questions regaring 3750 IVR configuration.
1. for IVR i didnt make any port of 3750 layer3 port. but 3750 is routing between my Vlans. is this Layer 3 routing ?
2. is it necessary to make layer 3 port by making "no switchport" command?
3. How can we change encapsulation of subinterface of Layer 3 port.
please help me in this regard.
regards
soshomile
01-05-2009 04:50 AM
The 3750 is a L3 switch.
U need not create any L3 ports on the 3750 as u create SVI's for the specific vlans,they are going to take care of IVR.
no it is not necessary to make L3 ports using no switchport this depends upon u r requirement.
AFAIk u cannot create sub-interfaces on this switch.
Mahmood
01-05-2009 05:03 AM
Dear thankyou.
for more detail please consider this example;
enduser first switch is 2950....it has 5 Vlans...Vlan 10-20-30-40 and 50. then i have another layer 2 switch 3500. i just make these Vlan into this as well. then i have 3750 fiber switch,. there i make all Vlan and assign the IP address which would be default gateway for the clients those are behind 2950 switch. for DHCP relay ...now i need to configure IP Helper-address on Vlan20...like
Vlan 20
ip address 1.1.1.1 255.0.0.0
ip helper-addres 10.1.1.1 255.0.0.0
by doing this my HDCP relay would configure...i already check that my client is able to ping the DHCP server.
is this complete configuration..?
please advice
regards
Soshomile
01-05-2009 04:55 AM
Hello Soshomile,
a multilayer switch can use logical interfaces called SVI for inter vlan routing :
vlan 2
name l2object
interface vlan 2
desc L3 SVI associated to vlan2
ip address x.x.x.x 255.255.y.z
think of it as a device connected to vlan2
you probably have SVIs on your C3750 if you are able to perform inter-vlans routing or an external device is doing it.
2) no see above
3) no you cannot do like in a router: you create SVIs for all vlans
the physical port is configured as a layer 2 trunk carrying vlans of interest
int g0/1
desc trunk to other device
switchport trunk encapsulation dot1q|isl
switchport mode trunk
swithcpot trunk allowed vlan 1,2,
the result is that all Vlans SVIs can talk with the outer world
Hope to help
Giuseppe
01-05-2009 05:05 AM
Hi soshomile,
As long as VLAN interfaces are up, configured with an IP address and you have enabled ip routing globally on the 3750, intervlan routing works
For the purpose Intervlan routing, you need not define a Layer 3 port. However if you wish to have L3 port on the switch, use the no switchport command under interface configuration mode.
The concept of using a subinterface for intervlan routing is when a router of stick method is used. However, here all you need is trunk port on the switch to pass all the VLANs.
Refer below for more details
Lejoe
