SCP error
Answered Question
Jan 5th, 2009
I'm trying to upgrade a router with CiscoWorks RME using SCP. It fails and says " SCP: [22 -> x.x.x.x:28475] send Privilege denied.".
The privilege level for this user is 15. I have checked the firewall and it's not blocking the traffic. Any ideas on where the privilege denied comes from? Thanks.
Correct Answer by Joe Clarke about 8 years 4 months ago
Here is a sample TACACS+ config:
! AAA authentication and authorization must be configured properly for SCP to work.
aaa new-model
aaa authentication login default group tacacs+
aaa authorization exec default group tacacs+
! SSH must be configured and functioning properly.
ip ssh time-out 120
ip ssh authentication-retries 3
ip scp server enable
See http://www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ftscp.html for more details.
Overall Rating: 5 (2 ratings)
Joe Clarke Mon, 01/05/2009 - 09:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What does your config look like? For SCP, you need a standard SSH config (which grants the user level 15 access) as well as:
What I typically use for local authentication and authorization is:
aaa new-model
aaa authentication login default local
aaa authorization exec default local none
username USER privilege 15 password PASS
patrickdonlon Mon, 01/05/2009 - 23:05
Here's my aaa config, I'm using authorization but I don't see any logs in my ACS when RME attempts to use SCP.
aaa authentication login default group tacacs+ local enable
aaa authentication enable default line group tacacs+ enable
aaa authorization config-commands
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
ip ssh version 2
Joe Clarke Mon, 01/05/2009 - 23:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to be using exec-level authorization. You have authorization only for config-commands and commands. See my example config.
[Edit]
When the user logs in, they should be immediately dropped to a '#' prompt. The "show privilege" command should indicate they have level 15 access.
Correct Answer
Joe Clarke Mon, 01/05/2009 - 23:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
aaa new-model
ip ssh time-out 120
patrickdonlon Tue, 01/06/2009 - 02:36
Thanks Joe, this was exactly what was missing,
aaa authorization exec default group tacacs+,
it now works perfectly.
grim Wed, 03/23/2016 - 17:50
For non-TACACS configs, this config also works:
aaa authorization exec default local if-authenticated
