ACE module configuring NTP
Jan 5th, 2009
I tried to configure an NTP Server and / or peer as described in the ace_adgd but the command NTP is not even there in the configuration mode of the Admin context. Is there a known issue with software version A2(1.0) or is there a configuration dependancy relating to ntp ? Many thanks in advance for your help and kind regards,
Andre
dario.didio Mon, 01/05/2009 - 06:48
  • Silver, 250 points or more
There is no possibility to configure NTP on an ACE module.
The ACE will take the time settings from the Supervisor.
Hope this helps.
Dario
andre.hansel Mon, 01/05/2009 - 07:33
Thanks Dario.
I just configured the timezones similar to SUP settings by hand and will check if it works.
Cheers, Andre
