Certificate needed on ASA 5510 for Cisco Secure Desktop ?
Answered Question
Jan 5th, 2009
I use Cisco Anyconnect "anyconnect-win-2.3.0185-k9" and ASA 8.0.4. I just want to use CSD for prelogin and check a registry key of the PC desktop .
It works fine but i have always in ASA log this message :
"Certificate validation failed. No suitable trustpoints found to validate certificate serial number: xxxxxxxxxxxxx, subject name: cn=CiscoSecureDesktop.
Jan 05 2009 15:00:50: %ASA-3-717027: Certificate chain failed validation. No suitable trustpoint was found to validate chain."
Do i need to install a certificate on ASA just to use the CSD module ? Or what is the mean to avoid this log message and avoid to use a CSD certificate ?
Thanks for your help.
David.
Correct Answer by mulatif about 8 years 4 months ago
Hi David,
The issue is more cosmetic and does not affect any functionality.
You can view the bug "CSCsr07594", which describes the issue and workaround in detail.
Naman
Overall Rating: 5 (1 ratings)
Correct Answer
mulatif Mon, 01/05/2009 - 13:54
  • Cisco Employee,
Hi David,
Naman
dnivelle Mon, 01/05/2009 - 23:54
Hi Naman,
Thanks for your response and your help. I need certificate, so i will let the configuration in this current state.
David.
