Error positioning ap's in WCS
Jan 5th, 2009
Hi all,
When i go to position ap's in the WCS, I get the following error:
[ServletException in:/pages/monitor/map/campusMoveLrads.jsp] Cannot find bean antennaInfoList in any scope'
I can add maps, add ap's, and can position them. It's when i goto save, i get the error.
WCS - 5.0.56.2
3 Controllers - 4402's
ap's - AIR-AP1231G-A-K9
Can anyone please help !
Matthew Ratliff Tue, 01/06/2009 - 07:38
uninstall your java from your client computer. Connect back up to WCS. It will provide you with the proper java version.
sschmidt Tue, 01/06/2009 - 12:34
Please go to Monitor > AP and click New Search. Pulldown "Search by" and choose "All Unassociated Aps". If there are returned results please make a note of the list and remove these and retry your tests.
sschmidt Tue, 01/06/2009 - 12:35
Also make sure that after you remove the unassociated APs that you do a refresh config from controller with delete to get the audit status identical for the controllers.
mrtechhcet Wed, 01/07/2009 - 04:45
Bingo... That was it. Thx u very much and to all who replied !
Chris
