VPN Client/Active Directory Question
Jan 5th, 2009
We had to disable an account of an employee, but his vpn session stayed on. How can I ensure the vpn session is terminated when we disable accounts/change account passwords?
Thanks in advance.
JORGE RODRIGUEZ Mon, 01/05/2009 - 13:09
  • Green, 3000 points or more
It is very possible the user was already connected when user/account was disabled, if you are using PIX/ASA you can disconnect the user via ASDM or through cli.
asa#vpn-sessiondb logoff name
you may also issue to see vpn client connections by detail, place a question mark for other options.
asa#show vpn-sessiondb ?
