Rate limite on Pix-515E
Answered Question
Jan 5th, 2009
Quick question the interface on a Pix how do I tell if their is any sort of rate filter on their?
Correct Answer by sachinraja about 8 years 6 months ago
hey Warren
Older versions of PIX did not do rate limiting.. with the new versions such as 7.x, pix can do a little bit of rate limiting features, using QOS..
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml#rate
URL explains the function of QOS on PIX.. if there is no rate-limiting applied on the outbound interfaces, it is a pure FE/GE port, and will be able to push that much traffic !
Hope this helps.. all the best.. happy new year..
Raj
Overall Rating: 5 (1 ratings)
Correct Answer
sachinraja Mon, 01/05/2009 - 12:23
  • Red, 2250 points or more
hey Warren
Raj
wgranada1 Mon, 01/05/2009 - 12:56
Thank you my version is 6.3 so I don't have a rate limit feature as you indicated. Thank you very much for the link and the explaination!!!!!!
