Why ASA 5520 vpn PLUS LICENSE IMAGE asa724-k8.bin
Jan 5th, 2009
I am trying to configure the L2L vpn.
The cmd "crypto map MAP 10 ipsec-isakmp"
is not finishing to enable L2L vpn instead gives error:incomplete command.
if we do ? then it shows "dynamic" then selecting the dynamic thne ? shows WORD.
Why cann't we select crypto map itself.
mulatif Mon, 01/05/2009 - 13:43
The above syntax is valid for IOS but not for ASA.
You need to configure the Crypto Map parameters as below
crypto map MAP 10 set transform-set <>
crypto map MAP 10 set peer <>
crypto map MAP 10 match address <>
And then apply the Crypto Map to the interface
crypto map MAP interface <>
You will also need to configure the ISAKMP policies and enable ISAKMP.
Naman
