CCNA experation
Jan 5th, 2009
I took the CCNA exam in March of 2003..Do I have to take the full CCNA exam again or is there an update test to re-establish my CCNA? appreciate the help thank you
Brandon Buffin Mon, 01/05/2009 - 13:08
  • Purple, 4500 points or more
The CCNA certification expires after 3 years. Yes, you will need to retake. There is no update or renewal option after a certification has expired. You will need to take 640-802 OR 640-822 and 640-816 to reestablish your CCNA.
http://www.cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html
Hope this helps.
Brandon
cameron.moody Mon, 01/05/2009 - 13:09
It is very clearly stated on the Cisco website that they are valid for 3 YEARS only so you will have to redo the exam again. Its also probably a good idea to be familiar and look at the the Cisco site if you intend on persueing it as this sort of information is very easy to find on their site!
crow930us Mon, 01/05/2009 - 13:10
  • Bronze, 100 points or more
You need to take the full exams in order to re-establish your CCNA certification. The limit is 3 years from when you last passed an equal or higher Cisco certification exam.
You can pick up more detailed information at the Cisco Learning Network: https://cisco.hosted.jivesoftware.com
This is a good place to pick up info regarding overviews & reviews, test questions, and how to register to take the exam.
crow930us Mon, 01/05/2009 - 13:11
Wow 3 replies in a 2 min span!!
ud0508500 Mon, 01/05/2009 - 13:27
ok was hoping for an easy ride..LOL appreciate the info...
