Limit speed of 3750 Gig port to 768
Jan 5th, 2009
We have a gig 3750 and want to limit the speed in and out of one of it's ports to 768 to simulate a fractional T1.
I'm having trouble finding the best way to do this.
Andy
andrew.butterworth Mon, 01/05/2009 - 14:27
  • Gold, 750 points or more
It should be pretty easy to do this in the ingress direction with a service-policy, but you might struggle on egress as the 3750 can't do egress service-policies. However the 3750 supports bandwidth limiting on egress ports. This is configured as a percentage and can be in the range 10-100. So the best you are going to get is 1Mbps by restricting a port to 10Mbps and applying a bandwidth limit of 10%.
switch(config)# interface FastEthernet 1/0/1
switch(config-if)# speed 10
switch(config-if)# duplex full
switch(config-if)# srr-queue bandwidth limit 10
This might not achieve what you are looking for though as it works by making the link idle for X-percent of the time - i.e. in this case it would be idle for 90% of the time.
To configure the inbound policy you would do this:
switch(config)# policy-map Restrict-768Kbps
switch(config-pmap)# class class-default
switch(config-pmap-c)# police 786432 8000 exceed-action drop
switch(config-if)# service-policy input Restrict-768Kbps
I haven't tested any of this but based on the documentation this is probably the best you can achieve. If you really want to simulate a fractional T1 why not get a pair of routers and a back-to-back serial cable and physically clock the link at 768Kbps? This would be a more realistic test.
Andy
