T1 CAS with Telco H323
Jan 5th, 2009
I am attemtping to turn up a T1 CAS E&M circuit with telco. I am running CUCM 6.1. and my router is a 2811. Does anyone have a sample IOS config I can use as a reference? Thanks in advance.
Nicholas Matthews Mon, 01/05/2009 - 13:28
controller T1 0/1/0
clock source internal
ds0-group 0 timeslots 1-24 type e&m-wink-start
dial-peer voice 1 pots
port 0/1/0:0
incoming called-number .
dial-peer voice 2 pots
destination-pattern 9.T
port 0/1/0:0
The rest will depend on if you're using SIP, MGCP, or H323. MGCP will look considerably different, but SIP/H323 would add this:
dial-peer voice 3 voip
session target ipv4:
destination-pattern 45...
codec g711ulaw
no vad
if SIP
