Possible to sort Corporate Directory on IP Phone by first name?
Jan 5th, 2009
Hey all,
If I go into the Corporate Directory on my IP phone and do a blank search, I get a listing of all users with "last name, first name" sorted by last name.
Is there a way to reverse this? Either on the phone or in call Manager?
Thanks!
Kenneth Mohammed Mon, 01/05/2009 - 14:18
  • Silver, 250 points or more
Hello Graham,
Im not sure if there are other ways to accomplish this, but I have seen people just input the last name in the first name field, and the first name in the last name field of the user configuration of the global directory. When you check the directory on the phone, it will then be sorted by first name.
Hope that helped, if so please rate.
graham.fleming Mon, 01/05/2009 - 14:19
Thanks for the reply, and I'm sure this would work. However, we have a large AD domain with hundreds of users so not practical for our purposes.
jbarcena Tue, 01/06/2009 - 08:19
  • Red, 2250 points or more
This is not supported by the cisco TAC,
however you can to the following:
- Go to your CCM server and look for the xmldirectoryinput.asp that is under
C:\CiscoWebs\IPPhoneServices\CCMCIP
- Open this file and look for the following output:
Directory Search
Enter search criteria
http://localhost:80/CCMCIP/xmldirectorylist.asp
First Name
f
A
To put LastName:
Change this line : First Name to
Last Name
Last Name
l
A
To put FirstName:
Change this line: Last Name to
First Name
