Sub-Int and Encapsulation
Answered Question
Jan 5th, 2009
I have the following routers ...
2650 and two 2620s running c2600-i-mz.123-26.bin. THe problem is that when I create a sub-interface the option for encapsulation is not there. If I am not mistaken, the IOS is the most current release for the routers for IP services and is advertised by cisco to work for both routers. Is it not a part of that IOS or is this caused by something else?
2650 -
2620 -
Thanks in advance,
Correct Answer by Jon Marshall about 7 years 9 months ago
You have the wrong feature set. You need a minimum of IP PLUS to support 802.1q encapsulation - see this link (table 2)
c2600-i-mz.123-26.bin = IP
c2600-is-mz.123-26.bin = IP Plus
Upgrade to IP Plus and the encapsulation command will be available.
Overall Rating: 5 (1 ratings)
