upgrade CM 5.x to 6.1.3
Answered Question
Jan 5th, 2009
Hi, gangs,
my customer has decided to buy software contract to upgrade CM from 5.x to 6.x. It takes quite a while for the purchase process, however, the customer is eager for the upgrade. Do I have to wait till I get the pack from Cisco, or I can download the upgrade image from Cisco web? During the upgrade, do I need license or something?
Jonathan
Correct Answer by Jaime Valencia about 8 years 2 weeks ago
unfortunately you'll have to wait, the only available upgrade to download is for upgrade from 6.1(1) or 6.1(2)
you'll also need the Feature License when going to 6.X
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 01/05/2009 - 19:30
java
