Unity servers AD Site change
Jan 5th, 2009
I have four Unity servers currently located in an Active Directory site. Recently the Unity servers AD site have been changed in AD so that it is in the same site as Exchange. Do I need to do anything to Unity? Rerun Permission Wizard?
Jaime Valencia Tue, 01/06/2009 - 07:33
  • Cisco Employee,
  • Hall of Fame,
    2011
ok, are you changing domain or are you simply changing the physical location of the servers??
java
if this helps, please rate
vinhnguyen Tue, 01/06/2009 - 19:27
We have different sites. I just pointed Unity to new domain controllers. Same domain. Same physical location.
Tommer Catlin Fri, 01/09/2009 - 09:31
  • Green, 3000 points or more
In the DC/GC reconnect tool, you can specify other Domain Controllers and Global Catalog servers.
If you have a completely new domain/forest, I would recommend a rebuild then. You can try the MS migration tool for Windows servers, but I can never get it work correctly afterwards.
