Eigrp - no auto-summary
Jan 5th, 2009
I have configured eigrp between 2 routers.
rt#1
network 10.10.10.0
network 172.16.1.0
no auto summary
rt#2
network 20.20.20.0
network 172.16.1.0
no auto summary
when i do show ip route on both the routers. It gives the following output,
rt1#
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 10.0.0.0/8 is a summary, 00:01:22, Null0
C 10.10.10.0/24 is directly connected, FastEthernet0/1
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 20.0.0.0/8 [90/30720] via 172.16.1.2, 00:00:44, FastEthernet0/0
D 20.20.20.0/24 [90/30720] via 172.16.1.2, 00:00:44, FastEthernet0/0
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
D 172.16.0.0/16 is a summary, 00:01:22, Null0
C 172.16.1.0/30 is directly connected, FastEthernet0/0
rt2#
D 10.0.0.0/8 [90/30720] via 172.16.1.1, 00:00:13, FastEthernet0/0
D 10.10.10.0/24 [90/30720] via 172.16.1.1, 00:00:13, FastEthernet0/0
D 20.0.0.0/8 is a summary, 00:00:18, Null0
C 20.20.20.0/24 is directly connected, FastEthernet0/1
D 172.16.0.0/16 is a summary, 00:00:18, Null0
Why is it showing summarized routes?
Giuseppe Larosa Tue, 01/06/2009 - 01:47
  • Hall of Fame,
    Founding Member
Hello Faizan,
have you added the no auto-summary in a second time ?
This could be a temporary effect
try the following
rt2# int f0/0
shut
! wait 60 seconds
no shut
Hope to help
Giuseppe
Richard Burts Tue, 01/06/2009 - 07:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Giuseppe
I am not clear why you think this might be a temporary effect or why you think that behavior might change if no auto-summary were configured a second time. I have never seen a router that needed this command to be entered a second time in order for it to take effect.
Faizan
The summary route is created by auto summarization or by manual summarization. I would guess that these routers are configured with summary-address on some interfaces. If you would post the output of show ip protocol it would help us to understand this. Even better would be to post the router configs so that we can see what is going on.
Rick
Giuseppe Larosa Tue, 01/06/2009 - 11:20
  • Hall of Fame,
    Founding Member
Hello Rick,
I was wrong in my previous post looking at the time of the routes I saw only 15 seconds age for all the routes.
the effect of auto-summary should be immediate.
I agree that probably some summarization is taking place here.
Happy New Year
Best Regards
Giuseppe
