Upgrade Cat6500 doc info
Jan 5th, 2009
Hello everyone,
I have successfully upgraded both 6509's, but the mentioned “0 to 3 seconds switchover time” (SSO mode) in the “Catalyst 6000/6500 Series Switches with Redundant Supervisor Engines Software Image Upgrade Configuration Example” was a little bit underestimated.
I experienced longer switchover due to a reset of all cards (exept the SUP720). This was a bit unexpected. Can you give any reason for this?
And will this happen again in a future upgrade?
We also wonder if the card rebooted at the same time or one per one?
Someone has a document who explained that?
hjacquemin Wed, 01/07/2009 - 23:29
I already had this information, but I still have no info on what happens with the line cards during a “high availability software upgrade”…
Do they reboot?
At the same time?
One after the other?
for information, I'm in SSO mode.
stierb Thu, 01/08/2009 - 01:29
Your question is answered in the document you referenced (the document id should be 71585). The explanation is under step 12 of the Software Update/Native Mode section. To summarize, after you upgrade the standby sup, it will come up in RPR mode because the IOS versions don't match.
Will it happen in a future upgrade? Yes.
Also, the linecards all reset at the time the failover occurs.
