FWSM Password Recovery
Jan 6th, 2009
I would like to reset the FWSM password while retaining all the configurations.
Please advise whether the steps below are correct
Router# hw-module module slot-number reset cf:1
Router# session slot slot-number processor 1
Log into Root.
[email protected]# clear passwd cf:partition_number
[email protected]# exit
hw-module module slot-number reset cf:partition-number
Please explain what does 'hw-module module slot-number reset cf:1'. Does it remove any of the configurations. Also how can I view all the partitions in FWSM.
Can I do the above on standby module while users are connected to active FWSM. Or does it need a downtime.
Yudong Wu Tue, 01/06/2009 - 15:22
Here is the procedure for password recovery
'hw-module module slot-number reset cf:1' does not remove any config, It just reboot FWSM from maintenance partition which is cf:1.
I believe that you can do it on standby module without interrupting the traffic. But I never try it before. So for safety, I suggest to do it during the change window.
