DMA Warnings on all users 7.0(1a)
Jan 6th, 2009
I am getting warnings in the DMA on nearly every user on the callmanager, this is the warning i get:
01/05/2009 20:50:25
Warning: Device or DeviceProfile=003094c38266 for user=gro not found in the database.
Condition: The Device found in the directory does not exist in the database
Solution: Please verify that the user is associated to a valid device or a device profile. Please add the mentioned device or device profile through CCM Admin pages or manually delete this value from the users CCN profile
I have checked in the ccm that the user exist and the phone he is controlling also exist. The callmanager is version 4.1(3)sr2 and the DMA tool is 7.0(1a)
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 01/06/2009 - 11:26
  • Cisco Employee,
  • Hall of Fame,
    2011
check this:
You can verify it by logging in to the DC directory and go to CCN->Profiles and double click on the Application profile(CCN Profile) of the user. Click on the Application Profile-2 tab and check the control devices. This would show the devices which are associated to the user. If another device with 003094c38266 exists delete it and add it from the CCM pages
java
if this helps, please rate
David Winther Mon, 01/12/2009 - 11:41
Everything looks ok when looking in the DC directory, i have made the upgrade now to 7.0.1 and all the associations works fine.
