Steel-Belted Radius server does not show sessions from Cisco5520
Jan 6th, 2009
VPN Remote clients are successfully authenticated through Steel-Belted Radius when connecting to Cisco5520.
For some wierd reason those sessions are not visible in "Current sessions" of the SBR Administrator although Radius logs confirm that the session is established.
On SB Radius server, cisco 5520 is configured as a Radius client, make/model: Cisco PIX Firewall(or Cisco VPN 3000 concentrator ) with cisco3k.dct dictionary (Radius vendor.ini file updated) Has anybody seen this problem before? What is missing? Many thanks in advance.
Ivan Martinon Fri, 01/09/2009 - 16:54
Perhaps you might need to enable accounting? I would go and check with the vendor why this sessions are not showing up.
