How to keep a VPN tunnel open?
Jan 6th, 2009
I am 17 routers Cisco 837
With
Cisco IOS Software, C837 Software (C837-K9O3SY6-M), Version 12.3(2)XE4, RELEASE SOFTWARE (fc1)
My tunnel is mounted but falls after 1 day
is there a way to automate the recovery of the tunnel without rebooting the router !!
thank's
Building configuration...
Current configuration : 3646 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ******
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 <removed>
no aaa new-model
ip subnet-zero
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
crypto isakmp policy 1
authentication pre-share
crypto isakmp policy 2
hash md5
crypto isakmp key xxxkey address ***************
crypto isakmp keepalive 10
crypto ipsec transform-set xxxtransform esp-null esp-sha-hmac
crypto ipsec df-bit clear
crypto map xxxmap 1 ipsec-isakmp
set peer **********
set transform-set xxxtransform
match address 151
interface Ethernet0
description CRWS Generated text. Please do not delete this:192.168.6.1-255.255.
ip address 192.168.6.1 255.255.255.0
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
no ip address
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname ****************
ppp chap password xxx
ppp pap sent-username ************** password xxx
ppp ipcp dns request
ppp ipcp wins request
crypto map xxxmap
hold-queue 224 in
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source list 105 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
access-list 23 permit 194.204.200.32 0.0.0.31
access-list 23 permit 192.168.6.0 0.0.0.255
access-list 102 deny ip 192.168.6.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 102 deny ip 192.168.6.0 0.0.0.255 ********* 0.0.0.3
access-list 102 permit ip 192.168.6.0 0.0.0.255 any
access-list 151 permit ip 192.168.6.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 151 permit ip 192.168.6.0 0.0.0.255 ********** 0.0.0.3
dialer-list 1 protocol ip permit
control-plane
mulatif Tue, 01/06/2009 - 08:12
Is there any VPN traffic flowing through the tunnel, when it goes down after 1 day ?
You can try to configure periodic ISAKMP keepalive at both ends, which should keep the tunnel UP.
"crypto isakmp keepalive periodic"
Naman
nkila_lna Wed, 01/07/2009 - 02:12
Thank you
But my router does not accept this command
accept only "crypto isakmp keepalive "
mulatif Thu, 01/08/2009 - 07:57
Maybe that is not available in the Software version you are running. You can check the CLI guide for your software version to verify, if that option is available.
Naman
nkila_lna Tue, 01/13/2009 - 02:28
Router#debug crypto ipsec
*Mar 1 23:56:01.366: SSH0: password authentication failed for root
*Mar 1 23:56:01.366: SSH0: AAA authentication fail reason: Password:
*Mar 1 23:56:04.730: %HIFN79XX-3-CMD_ERR: Hifn 79XX command returned error: (0x1044)
*Mar 1 23:56:04.730: chifn79xx_lopri_error: unknown error 0x1044
*Mar 1 23:56:04.730: IPSECcard: an error coming back 0x1044
*Mar 1 23:56:05.090: IPSEC(key_engine): major = 1
*Mar 1 23:56:05.090: IPSEC(key_engine): expired_timer
Router#debug crypto isakmp
*Mar 1 23:44:07.570: SSH0: password authentication failed for root
*Mar 1 23:44:07.570: SSH0: AAA authentication fail reason: Password:
*Mar 1 23:44:07.722: ISAKMP:(0:13:HW:2): retransmitting phase 1 MM_SA_SETUP...
*Mar 1 23:44:07.722: ISAKMP:(0:13:HW:2):incrementing error counter on sa: retransmit phase 1
*Mar 1 23:44:07.722: ISAKMP:(0:13:HW:2): sending packet to xx.xx.xx.xx my_port 500 peer_port 500 (R) MM_SA_SETUP
*Mar 1 23:44:08.410: ISAKMP (0:268435469): received packet from xx.xx.xx.xx dport 500 sport 500 Global (R) MM_SA_SETUP
*Mar 1 23:44:08.410: ISAKMP:(0:13:HW:2): phase 1 packet is a duplicate of a previous packet.
*Mar 1 23:44:08.410: ISAKMP:(0:13:HW:2): retransmission skipped for phase 1 (time since last transmission 688)
*Mar 1 23:44:12.162: SSH0: password authentication failed for root
*Mar 1 23:44:12.162: SSH0: AAA authentication fail reason: Password:
Ivan Martinon Tue, 01/13/2009 - 08:47
Hey there, let's clean a little bit your config, shall we?
First you should not have this line in there:
Cause it is using a list number that is not showing up on the config and most likely does not exist, this could cause a problem, so let's get rid of that line, unless you are indeed using it somewhere else.
Keepalives will not keep your tunnel up, instead they will detect whether the remote peer is active or not and if the remote peer is not active then they will force the tunnel to be renegotiated or turned down.
Traffic flowing through your tunnel at all time should keep your tunnel up, but if no traffic is flowing through the tunnel it is normal behavior for it to be brought down. The question here lies on why the tunnel does not recover back.
When the tunnel not coming up, can you get the outpt of the next and paste it here?
show crypto isakmp sa
"show ip nat trans | inc 500"
nkila_lna Wed, 01/14/2009 - 07:05
Router#show crypto isakmp sa
dst src state conn-id slot
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy MM_SA_SETUP 12 0
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy MM_SA_SETUP 11 0
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy MM_SA_SETUP 10 0
xxx.xxx.xxx.xxx yyy.yyy.yyy.yyy MM_NO_STATE 9 0 (deleted)
Router#show ip nat trans | inc 500
tcp xxx.xxx.xxx.xxx:1500 zzz.zzz.zzz.zzz:1500 ppp.ppp.ppp.ppp:80 ppp.ppp.ppp.ppp:80
tcp xxx.xxx.xxx.xxx:2500 zzz.zzz.zzz.zzz:2500 jjj.jjj.jjj.jjj:80 jjj.jjj.jjj.jjj:80
falain Sat, 01/17/2009 - 13:48
the best method I used is to maintain traffic in Tunnel:
I use an ip sla icmp-echo (ping) from spoke to datacenter sourced from loopback 0
In that way, source interface is always up even if ethernet lan interface is down
nkila_lna Tue, 01/20/2009 - 02:26
Session status: DOWN-NEGOTIATING
ROUTER#show crypto session detail
Crypto session current status
Code: C - IKE Configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal, X - IKE Extended Authentication
Interface: Dialer1
Peer: xx.xx.xx.xx/500 fvrf: (none) ivrf: (none)
Desc: (none)
Phase1_id: (none)
IKE SA: local yy.yy.yy.yy/500 remote xx.xx.xx.xx/500 Inactive
Capabilities:(none) connid:2 lifetime:0
IPSEC FLOW: permit ip 192.168.6.0/255.255.255.0 zz.zz.zz.zz/255.255.255.252
Active SAs: 0, origin: crypto map
Inbound: #pkts dec'ed 0 drop 0 life (KB/Sec) 0/0
Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 0/0
IPSEC FLOW: permit ip 192.168.6.0/255.255.255.0 192.168.1.0/255.255.255.0
Outbound: #pkts enc'ed 0 drop 20 life (KB/Sec) 0/0
falain Tue, 01/20/2009 - 10:52
have you done a
deb cry isa
deb cry ips
to see whats happening ?
nkila_lna Wed, 01/21/2009 - 02:02
ROUTER#debug crypto ipsec
Crypto IPSEC debugging is on
Jan 21 09:25:24.391: IPSEC(key_engine): major = 1
Jan 21 09:25:24.391: IPSEC(key_engine): expired_timer
Jan 21 09:26:11.580: %HIFN79XX-3-CMD_ERR: Hifn 79XX command returned error: (0x1044)
Jan 21 09:26:11.580: chifn79xx_lopri_error: unknown error 0x1044
Jan 21 09:26:11.580: IPSECcard: an error coming back 0x1044
Jan 21 09:26:24.420: IPSEC(key_engine): major = 1
Jan 21 09:26:24.420: IPSEC(key_engine): expired_timer
Jan 21 09:26:44.420: IPSEC(key_engine): major = 1
Jan 21 09:26:44.420: IPSEC(key_engine): expired_timer
Jan 21 09:26:50.080: IPSEC(sa_request): ,
(key eng. msg.) OUTBOUND local= xxx.xxx.xxx.xxx, remote= yyy.yyy.yyy.yyy,
local_proxy= 192.168.6.0/255.255.255.0/0/0 (type=4),
remote_proxy= 192.168.1.0/255.255.255.0/0/0 (type=4),
protocol= ESP, transform= esp-null esp-sha-hmac ,
lifedur= 3600s and 4608000kb,
spi= 0xB4C14AC1(3032566465), conn_id= 0, keysize= 0, flags= 0x400A
Jan 21 09:26:50.640: %HIFN79XX-3-CMD_ERR: Hifn 79XX command returned error: (0x1044)
Jan 21 09:26:50.640: chifn79xx_lopri_error: unknown error 0x1044
Jan 21 09:26:50.640: IPSECcard: an error coming back 0x1044
Jan 21 09:27:04.460: IPSEC(key_engine): major = 1
Jan 21 09:27:04.460: IPSEC(key_engine): expired_timer
Jan 21 09:27:20.088: IPSEC(key_engine): request timer fired: count = 1,
(identity) local= xxx.xxx.xxx.xxx, remote= yyy.yyy.yyy.yyy,
Jan 21 09:27:20.088: IPSEC(sa_request): ,
spi= 0x74AF07E2(1957627874), conn_id= 0, keysize= 0, flags= 0x400A
Jan 21 09:27:50.088: IPSEC(key_engine): major = 1
Jan 21 09:27:50.088: IPSEC(key_engine): expired_timer
Jan 21 09:27:50.088: IPSEC(key_engine): request timer fired: count = 2,
Jan 21 09:28:04.491: IPSEC(key_engine): major = 1
Jan 21 09:28:04.491: IPSEC(key_engine): expired_timer
nkila_lna Wed, 01/21/2009 - 02:08
ROUTER#debug crypto isakmp
Jan 21 09:45:46.563: ISAKMP:(0:17:HW:2): constructed NAT-T vendor-03 ID
Jan 21 09:45:46.563: ISAKMP:(0:17:HW:2): sending packet to XXX.XXX.XXX.XXX my_port 500 peer_port 500 (R) MM_SA_SETUP
Jan 21 09:45:46.563: ISAKMP:(0:17:HW:2):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
Jan 21 09:45:46.563: ISAKMP:(0:17:HW:2):Old State = IKE_R_MM1 New State = IKE_R_MM2
Jan 21 09:45:46.631: ISAKMP (0:268435473): received packet from XXX.XXX.XXX.XXX dport 500 sport 500 Global (R) MM_SA_SETUP
Jan 21 09:45:46.635: ISAKMP:(0:17:HW:2):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
Jan 21 09:45:46.635: ISAKMP:(0:17:HW:2):Old State = IKE_R_MM2 New State = IKE_R_MM3
Jan 21 09:45:46.635: ISAKMP:(0:17:HW:2): processing KE payload. message ID = 0
Jan 21 09:45:46.839: ISAKMP:(0:17:HW:2): processing NONCE payload. message ID = 0
Jan 21 09:45:46.839: ISAKMP: Looking for a matching key for XXX.XXX.XXX.XXX in default : success
Jan 21 09:45:46.839: ISAKMP:(0:17:HW:2):found peer pre-shared key matching XXX.XXX.XXX.XXX
Jan 21 09:45:46.839: %HIFN79XX-1-ERROR: host_sa_create, pPktEngEntryHMACFreeQ is empty
Jan 21 09:45:46.839: %HIFN79XX-3-CMD_ERR: Hifn 79XX command returned error: (0x1051)
Jan 21 09:45:46.839: IPSECcard: an error coming back 0x1051
Jan 21 09:45:46.839: ISAKMP:(0:17:HW:2):error from epa_ikmp_create_skeyid (MM_SA_SETUP)
Jan 21 09:45:46.843: -Traceback= 80C3E5C4 80C2C590 80C2C77C 80C4A584 80DCBD3C 80C4E05C 80C4DE98 80C22898 80C22DC4 802BDA2C 802C21F8
Jan 21 09:45:46.843: ISAKMP:(0:17:HW:2):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
Jan 21 09:45:46.843: ISAKMP:(0:17:HW:2):Old State = IKE_R_MM3 New State = IKE_R_MM3
falain Wed, 01/21/2009 - 10:33
seems to be due to hardware acceleration card
Try to switch off crypto card or try a more recent C837 IOS release. it sounds like this bug:
CSCec52778
Symptoms: IKE Phase 1 does not get established on a Cisco 837 router configured for RSA signature authentication when the VPN crypto card is activated. The following syslog messages are observed:
%CRYPTO-6-IKMP_CRYPT_FAILURE: IKE (connection id "id") unable to encrypt packet %HIFN79XX-3-CMD_ERR: Hifn 79XX command returned error: (0x10FF)
Also a traceback might be seen.
Conditions: This has been observed with Cisco IOS Release 12.2(13)ZH2 and 12.3(2)T1
Workaround: Switching off the crypto card will resolve the issue.
connect2world Sun, 07/24/2011 - 01:00
I believe your config statement has left out the some important ip-access list rule.Add these statements on top of the access-list 102(subsitute the destination_peer_ip with your actual peer IP.):
access-list 102 deny   udp host any host destination_peer_ip eq isakmp
access-list 102 deny   udp host any host destination_peer_ip eq non500-isakmp
access-list 102 deny   ahp host any host destination_peer_ip
access-list 102 deny   esp host any host destination_peer_ip
access-list 102 deny   pcp host any host destination_peer_ip
The additional 5 statements must take place before  your 192.168.x.x subnets access-list  inorder to prevent ipsec/isakmp peer communication traffic from being NAT. This will ensure tunnel stay up and from having random vpn disconnect.The destination peer must also have those statement in reverse order so that both peer can have 2 way communication for tunnel establishment.
