01-06-2009 04:26 AM
Hi Expert,
I am now facing a problem to discover MSFCs in a few different campus LANs. Those MSFCs are initially discovered (for the first few discoveries upon successful LMS server installation).
However, they are no longer in neither the Reachable list nor the Unreachable list followed by the subsequent discoveries.
A debugging CSDiscovery.log while using ping sweep to discover one of the MSFC IP addresses is posted here.
From the log, I noticed that the device is discarded upon DCR getting the sysName and object ID. Not sure if this is the key problem. Please advice. Thank you very much!
Yi Shyuan
Solved! Go to Solution.
01-06-2009 08:49 PM
Again, check the credentials for the MSFC in DCR (under Common Services > Device and Credentials > Device Management). Reenter them to make sure they are correct.
01-06-2009 07:44 AM
At the same time, it can also be noticed that the DCR Display name is the IP Address of the device. Even though Global setting is set to display Host Name in DCR and preferred management IP Address is the SysName, it seems like DCR can only display the IP Address in Device management.
Yi Shyuan
01-06-2009 09:17 AM
No. This is dependent on the IP address being reverse resolvable in DNS or the server's local hosts file. Verify that 10.71.137.253 is resolvable to a hostname.
As for the Discovery, it looks okay in this log. As with your 6500, make sure the credentials in DCR are still correct for this MSFC. Also, review your Discovery filters to make sure they still allow this MSFC to be discovered.
01-06-2009 07:37 PM
Since DNS servers in the LANs are not updated and not synchronize among themselves, I suspect the IP address is not resolvable to a hostname.
However, there is not IP Address is excluded in the filter when discovery is done for the MSFC IP Address.
01-06-2009 08:49 PM
