WLC failover
Jan 6th, 2009
I have 2 4404 WLCs and 41 APs. these 41 AP connect to 1 4404 WLC. I want to added the second WLC as a backup WLC. since i have 2 6509 core switches , I want to primary WLC connects to core1 switch, and the backup WLC connects to core2 switch . Please tell me how to configure the WLCs
failvoer .really thanks you help
Overall Rating: 5 (2 ratings)
edward.weir Tue, 01/06/2009 - 08:13
You would need to configure both WLC to ensure they are both in the same mobility group in order for the AP's to know of both WLCs. You would also need to configure the AP's with the Primary, Secondary or Tertiary WLC in order for that AP to know which WLC to join.
cscyangyu Tue, 01/06/2009 - 08:17
Do i just need configure the AP's with the Primary, Secondary on primary WLC, or on both WLCs.
edward.weir Tue, 01/06/2009 - 13:27
You can configure the Primary and Secondary on the WLC the AP is currently connected to. That change would be saved on the AP side.
cscyangyu Wed, 01/07/2009 - 05:32
I think you guys given me a perfect solution. I will test it at this weekend.
Thank you guys help
