Combining ISO files
Answered Question
Jan 6th, 2009
  • Silver, 250 points or more
I`ve just downloaded the two IOS files I require for an upgrade and have combined them using the COPY UCSInstall.....PART1OF2+ UCS....PART2OF2 UCSInstall....SGN.ISO as per Cisco but the resultant file is very much smaller - is this correct,Am I missing something?
Correct Answer by htluo about 8 years 3 months ago
you forgot the /B option (which means binary mode).
COPY /B File1+File2 Dstfile
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 01/06/2009 - 08:50
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
If I recall the file should be the size of the 2 separate files combined, it's around 2.5 Gb.
HTH,
Chris
Correct Answer
htluo Tue, 01/06/2009 - 21:09
  • Red, 2250 points or more
iptuser55 Wed, 01/07/2009 - 02:25
Thanks for that - it was the /B statement but the resultant file was as a .sgn extension not sgn.iso - is this correct?
htluo Wed, 01/07/2009 - 09:46
you could rename it to .sgn.iso. Not sure if CUCM is picky on file extensions.
