CME instead of SRST
Answered Question
Jan 6th, 2009
I haven't tried this yet, but was just wondering if there are any gotchas/issues when using CME instead of SRST. I was specifically thinking about 2 points:
1) Do you need to ensure the phone loads in CME are the same as CM, or wouldn't it cause the phones to upgrade/downgrade each time if not.
2) Swapping to CME should be straight forward, but how does a phone swap back. Would it still check its primary CM list even though registered with CME. Or would I just create a list in CME that had the CM as primary?
Correct Answer by Chris Deren about 8 years 4 months ago
1. Don't setup tftp on CME, this way the current phone load from CM will be used
2. It works the same way as normal SRST does, when a CM becomes available the phone will wait 120 seconds (default) to register back with it.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 01/06/2009 - 09:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
billybjo1 Tue, 01/06/2009 - 09:15
great thanks. I think I only just realised there is actually a CME-SRST feature, whereas I was thinking about normal CME.
loganseth Mon, 09/14/2009 - 13:26
what is this cme-srst feature you speak of? sounds intriguing...
