Editing VPN Client MSI
Jan 6th, 2009
Hello;
Does anyone have documentation on editing the VPN client setup MSI file to add company logos, ini and pcf files? The one located on the Cisco website isn't very helpful I find.
Thank You
Mark Yeates Tue, 01/06/2009 - 13:30
  • Gold, 750 points or more
Sean,
I am not too sure about the company logos, but what I do is include the .pcf profiles with the installation. All you do is copy the .pcf file(s) if you have multiple profiles into the same folder as the installer. It will be copied to the correct location. This link may be the same one you were referring to but if not I hope it helps.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/rel4_0/admin_gd/vcach5.htm#30347
Mark
P.S. I believe the same goes for the setup ini file, but have never tested it before.
DialerString_2 Mon, 01/19/2009 - 07:47
  • Bronze, 100 points or more
Sean,
Did you ever figure out how to accomplish this? I've been all over the net and Cisco.
sean-boston Mon, 01/19/2009 - 12:58
Hello DialerString;
No, I haven't figure it out. There is just no good documentation out there.
