T1 to Chanelized DS3 EIGRP Flapping route
Answered Question
Jan 6th, 2009
  • Bronze, 100 points or more
I have a 3725 with a T1 connection that terminates into a channelized DS3 on a 7200.
The 3725 sends and recieves the multicast EIGRP messages with no encap failures (verified with debug IP packet that it is sending, and the addition of the 7200 into the EIGRP neighbor table for recieving).
On the 7200, I verified it is sending the multicast hello's with no encap failures, but it is not acknowledging the multicast packet from the 3725 (possibly not recieving it at all).
There are other T1's on the channelized DS3 that are working properly and are sending and recieving the multicast hellos.
There are no errors on the serial interfaces.
There are no errors when viewing "show controllers"
3725 Config
router eigrp 64
passive-interface FastEthernet0/1.201
passive-interface FastEthernet0/1.213
network 10.0.0.0
auto-summary
controller T1 0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
interface Serial0/0:0
ip address 10.249.16.2 255.255.255.252
ip nat outside
IP-EIGRP neighbors for process 64
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 10.249.16.1 Se0/0:0 13 00:00:53 1 5000 24 0
1 10.170.2.2 Se0/1:0 14 1w3d 5 200 0 11137
2 10.4.37.254 Fa0/1.4 13 8w0d 1 200 0 120875
.Jan 6 14:02:12 CST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 64: Neighbor 10.249.16.1 (S
erial0/0:0) is down: retry limit exceeded
.Jan 6 14:02:15 CST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 64: Neighbor 10.249.16.1 (S
erial0/0:0) is up: new adjacency
.Jan 6 14:03:35 CST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 64: Neighbor 10.249.16.1 (S
.Jan 6 14:03:38 CST: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 64: Neighbor 10.249.16.1 (S
7200 Config
router eigrp 64
network 10.0.0.0
no auto-summary
controller T3 2/1
t1 1 channel-group 0 timeslots 1-24
t1 2 channel-group 0 timeslots 1-24
t1 3 channel-group 0 timeslots 1-24
t1 4 channel-group 0 timeslots 1-24
t1 5 channel-group 0 timeslots 1-24
t1 6 channel-group 0 timeslots 1-24
t1 7 channel-group 0 timeslots 1-24
t1 8 channel-group 0 timeslots 1-24
t1 9 channel-group 0 timeslots 1-24
t1 10 channel-group 0 timeslots 1-24
t1 11 channel-group 0 timeslots 1-24
t1 12 channel-group 0 timeslots 1-24
t1 13 channel-group 0 timeslots 1-24
t1 14 channel-group 0 timeslots 1-24
t1 15 channel-group 0 timeslots 1-24
t1 16 channel-group 0 timeslots 1-24
t1 17 channel-group 0 timeslots 1-24
t1 18 channel-group 0 timeslots 1-24
t1 19 channel-group 0 timeslots 1-24
t1 20 channel-group 0 timeslots 1-24
t1 21 channel-group 0 timeslots 1-24
t1 22 channel-group 0 timeslots 1-24
t1 23 channel-group 0 timeslots 1-24
t1 24 channel-group 0 timeslots 1-24
t1 25 channel-group 0 timeslots 1-24
t1 26 channel-group 0 timeslots 1-24
t1 27 channel-group 0 timeslots 1-24
t1 28 channel-group 0 timeslots 1-24
interface Serial2/1/9:0
description ######################################
ip address 10.249.16.1 255.255.255.252
ip route-cache flow
service-policy output Voip-T1
Correct Answer by Giuseppe Larosa about 8 years 5 months ago
you probably should rewrite the acl 103 to deny eigrp packets
access-list 103 deny eigrp any any
access-list 103 permit ip any any
Hope to help
Giuseppe
Overall Rating: 5 (3 ratings)
Richard Burts Tue, 01/06/2009 - 11:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Craig
There are a couple of things I notice for which I would like some additional details. On the 3725 the serial interface has nat outside. Can you provide that details of how NAT is configured on the router? And on the 7200 there is a service-policy configured. Can you provide details of the service policy?
Rick
xcz504d1114 Tue, 01/06/2009 - 12:19
Rick,
Thanks for the reply.
In regards to the NAT on the 3725, it is used Untrusted Guest Wireless use at that location, I'm not fond of the implementation they used for it.
ip nat inside source list 103 interface Serial0/0:0 overload
interface FastEthernet0/1.99
encapsulation dot1Q 99
ip address x.x.x.1 255.255.255.0
ip nat inside
no ip route-cache
As for the 7200 service policy, it's for VoIP QA
policy-map Voip-T1
class VoIP-RTP-UnTrust
set dscp ef
priority percent 35
class VoIP-Control-UnTrust
bandwidth percent 5
set dscp af31
class BEST-EFFORT-DATA
set dscp default
class class-default
fair-queue
Richard Burts Tue, 01/06/2009 - 12:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Craig
I do not see any obvious problem, but agree with you that I do not like the way that the NAT was done. Would it be possible to (temporarily) remote the nat outside from the serial interface and see if the behavior changes?
Have you tried a shut/no shut on the serial interface?
Could you also post the output of show interface from both routers?
Rick
xcz504d1114 Tue, 01/06/2009 - 13:17
From the 3725 (T1 Side)
Serial0/0:0 is up, line protocol is up
Hardware is GT96K Serial
Internet address is 10.249.16.2/30
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:09, output hang never
Last clearing of "show interface" counters 2w0d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 733
Queueing strategy: weighted fair
Output queue: 0/1000/64/733 (size/max total/threshold/drops)
Conversations 0/89/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
5 minute input rate 5000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
25699390 packets input, 4082553795 bytes, 0 no buffer
Received 150735 broadcasts, 0 runts, 0 giants, 0 throttles
229 input errors, 229 CRC, 80 frame, 36 overrun, 0 ignored, 122 abort
26691539 packets output, 3717628125 bytes, 0 underruns
0 carrier transitions
Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
Here is the output of the Show Controller T1 as well
T1 0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040408, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (601 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
From the 7200 (Channelized DS3)
Serial2/1/9:0 is up, line protocol is up
Hardware is PA-MC-2T3+
Description: ###################
Internet address is 10.249.16.1/30
Encapsulation HDLC, crc 16, loopback not set
Last input 00:00:03, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 96828
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/96828 (size/max total/threshold/drops)
Conversations 0/146/256 (active/max active/max total)
Reserved Conversations 1/1 (allocated/max allocated)
Available Bandwidth 539 kilobits/sec
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 6000 bits/sec, 3 packets/sec
26691535 packets input, 3717629016 bytes, 0 no buffer
Received 150729 broadcasts, 0 runts, 0 giants, 0 throttles
97 input errors, 11 CRC, 36 frame, 0 overrun, 0 ignored, 50 abort
25699429 packets output, 4082567219 bytes, 0 underruns
0 carrier transitions no alarm present
Timeslot(s) Used: 1-24, subrate: 1536Kb/s, transmit delay is 0 flags
non-inverted data
And show controller T3
T1 9 is up
timeslots: 1-24
FDL per AT&T 54016 spec.
No alarms detected.
Framing is ESF, Clock Source is Internal
Data in current interval (83 seconds elapsed):
0 Unavail Secs, 0 Stuffed Secs
0 Line Code Violations,0 Path Code Violations,
Richard Burts Tue, 01/06/2009 - 13:24
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Craig
Thanks for the output, but I am afraid it does not show any problem. Does the 7200 see the 3725 as a neighbor? What is in the output of show ip eig int Serial2/1/9:0?
Rick
xcz504d1114 Tue, 01/06/2009 - 13:21
Good call on the NAT, sure enough as soon as I dropped it fromt he interface I saw the neighbor relationship come up on the DS3 side. Now I have to sit here for a minute and contemplate why :)
Thanks for the help Rick!
Correct Answer
Giuseppe Larosa Tue, 01/06/2009 - 13:25
  • Hall of Fame,
    Founding Member
Hope to help
Giuseppe
Richard Burts Tue, 01/06/2009 - 13:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Craig
I am glad that you found the issue was related to the NAT. I am not sure exactly what the issue is, but I have seen some strange stuff with NAT when it tries to use an extended access list with permit any any. I would suggest re-writing it to use a standard access list and in the standard access list specify the address range of the interface where the clients are.
Rick
xcz504d1114 Tue, 01/06/2009 - 14:10
Yeah, I re-wrote the access-list, it was definately the any any statement, I ended up using the extended ACL and just denying the EIGRP from being translated.
Thanks for all of your help Rick and Giuseppe,
Craig
