message of HighUtilization from cisco LMS
Answered Question
Jan 6th, 2009
Hi to all,
I'm getting this message from my cisco LMS
De: Lan_XXX [mailto:Lan_XXX]
Enviado el: Lunes, 05 de Enero de 2009 11:40 p.m.
Para: ZZZ, AAA [CUSC]
Asunto: 0008H06 ; 128.127.254.1 ; Mon 05-Jan-2009 23:39:39 CST ;
Critical ; Active
EVENT ID = 0008H06
ALERT ID = 00001L8
TIME = Mon 05-Jan-2009 23:39:39 CST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 128.127.254.1
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION =
HighUtilization::Component=PORT-128.127.254.1/95 [Gi6/32]
[EtherChannel-2];OutputPacketRate=5151.112
PPS;Type=ETHERNETCSMACD;CurrentUtilization=51.333706
%;InputPacketRate=43942.13 PPS;TrafficRate=6.4167132E7
BYPS;UtilizationThreshold=40;DuplexMode=FULLDUPLEX;MaxSpeed=1000000000;
CUSTOMER IDENTIFICATION = Switches
I believe i have to increase the UtilizationThreshold in order to stop the LMS sending this message but I can't find where to change it, I already checked the Device Fault Manager in the Configuration Polling and Thresholds -> Managing Thresholds tab but I can't find it.
Can you help me with this?
Thanks in advance
Correct Answer by Joe Clarke about 8 years 1 month ago
You can increase the threshold under DFM > Configuration > Polling and Thresholds > Managing Thresholds. When you're satisfied, go to DFM > Configuration > Polling and Thresholds > Apply Changes to active the new threshold. If you do not do this, then the threshold will not actually change.
You will need to increase the port utilization to at least 52% to prevent this event from being generated.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 01/06/2009 - 13:44
