2620xm SLOW ADSL when using the WIC-1ADSL
Jan 6th, 2009
Hello..
I have a 2620xm router with AT&T DSL 6000/768 service....
When I setup pppoe using the WIC-1ADSL my speed is 2369Kbps... (DSL>>Router>>Lan)
When I setup pppoe with a DSL modem infront of the router my speed is 5460Kbps.... (DSL Modem>>Router>>Lan)
The 2620xm info:
IOS c2600-adventerprisek9-mz.124-19
48mb Flash/256mb Ram
2 FastEthernet interfaces
1 Serial interface
1 ATM interface
Current Config:
! Last configuration change at 15:27:30 CDT Tue Jan 6 2009
! NVRAM config last updated at 14:15:59 CDT Tue Jan 6 2009
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname xxxxxxx
boot-start-marker
boot-end-marker
logging count
logging buffered 16000 debugging
logging console informational
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone CDT -6
clock summer-time CDT recurring
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip domain name xxxxxxxxxxxx
ip name-server xxxxxxxxxxxx
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip ddns update method sdm_ddns1
DDNS both
ip ddns update method sdm_ddns2
HTTP
add xxxxxx:xxxxxx-members.dyndns.org/nic/update?system=dyndns&hostname/nic/update?system=dyndns&hostname</A>=<h>&myip=<a>
remove xxxxxx:xxxxxx-members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
interval maximum 28 0 0 0
interval minimum 28 0 0 0
username xxxxxx privilege 15 view root secret 5 xxxxxxxxxxxxxxxxxxxxx
buffers tune automatic
interface FastEthernet0/0
description (LAN) xxxxxxxxx-ISA 2006 Server$ETH-LAN$
ip address xxxxxxxxxxxx xxxxxxxxxxxxxxx
ip access-group 100 in
ip helper-address xxxxxxxxxxxxx
ip mask-reply
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1460
speed 100
full-duplex
no mop enabled
interface Serial0/0
no ip address
shutdown
no fair-queue
interface ATM0/1
description (WAN) AT&T ADSL
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
dsl enable-training-log
hold-queue 224 in
interface ATM0/1.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet1/0
description (DMZ)
ip nat inside
speed 100
full-duplex
interface Dialer0
description Virtual Dial Interface
ip ddns update hostname xxxxxxxxxxxxxxx
ip ddns update sdm_ddns2
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username [email protected] password 7 xxxxxxxxxxxxxxxxx
ppp ipcp dns request
ppp ipcp route default
ip forward-protocol nd
ip http server
ip http access-class 1
no ip http secure-server
ip nat inside source list 2 interface Dialer0 overload
*** NAT INFO REMOVED BECAUSE OF SIZE ***
logging trap debugging
logging xxxxxxxxxxxx
***ACL LIST REMOVED BECAUSE OF SIZE ***
dialer-list 1 protocol ip permit
snmp-server community public RW
control-plane
line con 0
transport preferred none
speed 115200
line aux 0
line vty 0 4
access-class 101 in
login
ntp logging
ntp clock-period 17180358
ntp server xxxxxxxxxxx source FastEthernet0/0 prefer
end
I have attached some of the SHOW INTERFACE commands......
I know this is a huge post but I am posting all information possible......
Thanks.......I am just not sure if I missed a command somewhere....
I would be thankful for ANY help or information.....
Dave
SCORPION69 Thu, 01/08/2009 - 17:59
Well seeing how I got many suggestions and help.....I was persistent in solving the issue......so I dug deep into every bit of Cisco documentation I could find...
The speed issue is resolved...
- Using the WIC-1ADSL
- No DSL modem in front of the router...
- Both Upload/Download speed and latency is actually BETTER than it was before....
Thanks once again.......
Sam Smiley Tue, 03/03/2009 - 13:58
Hi Scorpion,
I have run into this problem before on 2600XM devices running the C2600-ADVENTERPRISEK9-M IOS. I've run into this on a couple of occasions configuring the 2600XM devices. The way I worked around it was to install a standard IOS image. This gave correct speeds with 2 AT&T installs that I have done.
I would be very interested in how you solved this problem on your install. Please post and let's compare notes.
Sam
