Strange BGP issue
Jan 6th, 2009
I have an issue where one locally connected network is not being advertised by BGP. All the other networks are working fine. Would the "clear ip bgp soft" command work possibly?
Non-working network:
router1#show ip route 10.xx.x2.0
Routing entry for 10.xx.x2.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
Routing Descriptor Blocks:
* directly connected, via VlanXX2
Route metric is 0, traffic share count is 1
Working network:
router1#show ip route 10.xx.x3.0
Routing entry for 10.xx.x3.0/25
Redistributing via bgp XXXXX
Advertised by bgp XXXXX
* directly connected, via VlanXX6
There are no route-map filters in place. We are redistributing routes from ospf to bgp. Other routers in the OSPF area are learning about this network without issue. The only issue is getting it to BGP.
xcz504d1114 Tue, 01/06/2009 - 14:16
  • Bronze, 100 points or more
Can you post your OSPF and BGP configs?
Richard Burts Tue, 01/06/2009 - 14:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Daniel
Would you post the BGP configuration? My first guess would be that there is some issue with the network statements under BGP - perhaps the network statement for the route that does not work is not using the correct subnet mask?
Rick
maahiraahi Tue, 01/06/2009 - 18:48
will help if u share bgp conf , ospf & static route conf
