Richard Burts Tue, 01/06/2009 - 19:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
raahi
There are several steps that happen when you make an interface active in EIGRP.
- when you configure an EIGRP network statement (configuring a mask on the network statement is optional) EIGRP evaluates the network statement (what network/subnet does it include) and scans all of the active interfaces looking for all interfaces that are included within that network statement.
- EIGRP becomes active on those interfaces.
- EIGRP sends hello messages on all interfaces which have become active.
- EIGRP listens for hello messages on the interfaces which have become active.
- when EIGRP receives an EIGRP hello on one of these interface it checks for several conditions: is the neighbor in the same EIGRP AS; is the neighbor source address in the same subnet of this interface.
- if the parameters in the EIGRP hello message are compatible then the neighbor process is initiated which will lead the neighbors to share their routing information and to become active neighbors.
Rick
maahiraahi Wed, 01/07/2009 - 00:25
fine, my problem : my routers are unable to form neighbor each other but swithces can .any static route is req. from both the routers ?
royalblues Wed, 01/07/2009 - 01:09
  • Green, 3000 points or more
You router interfaces seem to be having different subnet ip adddress and hence will not form adjacencies between each other
Narayan
maahiraahi Sat, 01/10/2009 - 03:50
static routes will solve my prob. or ip address needs to be changed ?
Tshi M Fri, 01/09/2009 - 12:44
  • Silver, 250 points or more
It will be great to see your configuration. But, take a look below.
left side:
router eigrp 2
network 1.1.1.0 0.0.0.255
network 1.1.2.0 0.0.0.255
network 1.1.4.0 0.0.0.255
network 1.1.5.0 0.0.0.255
Right side
router eigrp 2
network 1.1.3.0 0.0.0.255
maahiraahi Sat, 01/10/2009 - 03:55
router eigrp 51
redistribute connected
redistribute static
redistribute bgp as#
network 1.0.0.0
default-metric 2000 10000 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
Richard Burts Sun, 01/11/2009 - 19:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
raahi
There is not quite enough information here for us to find the problem. Would you post the output of show ip interface brief, and of show ip eigrp interface of the router of this post?
Also would you post the output of the EIGRP configuration, and of show ip interface brief and of show ip eigrp interface from the router that you want to be an EIGRP neighbor?
Rick
