ASA-SSM 10
Jan 6th, 2009
Hi ,
I have ASA5520 and module ASA-SSM 10.When i use the asdm ,I can open GUI for ASA main menu and IPS.But ASA main menu is working fine,but when i click the IPS icon,its not connecting the ASA-SSM-Module.I'am geting some error.
Unable to Access the IPS SSM through ASDM
Problem:
The Error connecting to sensor. Error Loading Sensor error message displays on the
GUI.
Solution:
Check the IPS SSM management interface is up/down?
UP only.
and check its configured IP address, subnet mask
and default gateway.
192.168.1.3/24,192.168.1.2
This is the interface to access the Cisco Adaptive Security Device Manager (ASDM)
Software from the local machine.
yes i can
Try to ping the management interface IP address of IPS SSM from the local
machine that you want to access the ASDM.
yes ,i can.
But still i am geting error same error.
smalkeric Mon, 01/12/2009 - 06:57
  • Silver, 250 points or more
You may try using the ASDM version 5.2.1
