EasyVPN Tunneled Networks Inaccessible
egleas522
I have 5510's running ASA7.2 @ my HQ and remote sites running 5505's with L2L or EasyVPN connections. I upgraded my home EasyVPN 5505 to ASA 8.0. The transition was seamless except that I can now only access the networks that are being tunneled that are directly connected to the 5510's. I can no longer access the other L2L or EasyVPN networks that I could access before. No changes were made to tunnel groups on the Group Policy on the 5510's. Is this an incompatability of my 8.0 5505 client and 5510 server? Or did 8.0 add a client side function for split remote tunneled networks.
mvsheik123
Level 7
Level 7
Is 'hairpinvpn config and other related commands (same-security-traffic permit intra-interface) enabled..? try the debug icmp trace , it is very helpful in determining where packets being dropped. Also, if possible, post the configs, someone will be able help you.
hth
MS
