active vlan defination
Answered Question
Jan 6th, 2009
  • Bronze, 100 points or more
Hi every body!
my book defines active vlan as vlan which is defined on switch and and has ports assigned to it.
However ,same book shows the out put of " show vlan"
vlan name status ports
2 vlan 0002 active fa0/4
5 vlan 0005 active
The vlan 5 is shown as active though no port is assigned to it which contradicts the book definition of active vlan.
Any thoughts?
Thanks a lot!
Correct Answer by Richard Burts about 8 years 3 months ago
Sarah
The other thing that will put a VLAN into the active state is if there is a trunk port on the switch which carries traffic for that VLAN. Does this switch have a trunk port which has VLAN 5 as one of its VLANs?
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 01/06/2009 - 19:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sarah
Rick
sarahr202 Tue, 01/06/2009 - 21:26
Thanks Rick for your reply!
well book just shows the output of " show vlan" for illustrative purpose , i believe.
Your point makes sense because if switch has trunk carrying vlan 5, then it is regarded as active as well.
Thanks a lot!
